larsenelund
Repeated measures anova with fixed effect
I'm new to JMP, and have not been able to figure this out..
In my trial, I've obtained blood from 10 patients to evaluate 5 different biomarkers (these are not to be run against each other). Within each of these marker-groups, each patient is represented at 5 different points (each patient is represented in serum timepoint 1 and 2, plasma timepoint 1 and 2 + one more) and those I do want to compare against each other. Thus, I want to run an repeated-measure ANOVA with "patient" as fixed effect. Is this possible in JMP?
Thanks heaps,
Lars
ron_horne
Re: Repeated measures anova with fixed effect
hi larsenelund​,
perhaps this link can help:
Full Factorial Repeated Measures ANOVA Add-In
at the end of the page there are links to videos that demonstrate it very clearly.
ron
ron_horne
hi larsenelund​,
ron
There is also a Mixed Model example in the Help system that has Fixed and Repeated measures.
Help==>Contents
Fitting Linear Models==>Mixed Models==>Additional Examples==>Repeated Measures Example
larsenelund
Thank you, that was spot-on!
