Arocha1
Reorganizing A Table by Items Within A Column
I have a system that calibrates data and outputs the information as so:
Tire IDTreadDepthDraguSpsi
2326Inner0.6185840.1177740.41731421.15549
2326Outer0.7408410.4170790.41731421.15549
2327Inner0.3290650.2189030.36507125.65573
2327Outer0.4780550.2149530.36507125.65573
The Tire ID is read twice, once for the inner tread readings, and once for the outside. Is there a script I can use to reorganize it as such:
Tire IDInner DepthOuter DepthInner DragOuter DraguSpsi
23260.618584450.740840570.11777370.41707940.4173121.1555
23270.329064510.478055450.21890250.21495270.3650725.6557
Here, there is only one entry per tire. The entries for Depth and Drag have been renamed by Inner or Outer and the identical columns have just been merged into one. This is a snip of a much larger sheet with many more columns - some different, others the same.
Ideally, the script can determine what cells are the same according to tired ID and just remove replicates. But a script that's set up with predetermined names could work too, since the column names never change.
Thank you!
@jthi@txnelson , you two helped tremendously last time! Thank you for that! I don't really know what approach to take and haven't been able to find anything similar enough in previous solutions.
pmroz
Re: Reorganizing A Table by Items Within A Column
This is a brute-force approach, but it works.  Note the variables for split columns and nonsplit columns.
dt = New Table( "Base Tire Data", Add Rows( 4 ),
	New Column( "Tire ID", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [2326, 2326, 2327, 2327] ) ),
	New Column( "Tread", Character( 16 ), "Nominal",
		Set Values( {"Inner", "Outer", "Inner", "Outer"} ) ),
	New Column( "Depth", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [0.618584, 0.740841, 0.329065, 0.478055] ) ),
	New Column( "Drag", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [0.117774, 0.417079, 0.218903, 0.214953] ) ),
	New Column( "uS", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [0.417314, 0.417314, 0.365071, 0.365071] ) ),
	New Column( "psi", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [21.15549, 21.15549, 25.65573, 25.65573] ) )
nr = nrows(dt);
dtt = New Table( "Split Tires");
dtt << new column("Tire ID", Numeric, "Continuous", Format( "Best", 12 ));
split_cols = {"Depth", "Drag"};
nonsplit_cols = {"uS", "psi"};
for (i = 1, i <= nitems(split_cols), i++,
	inn_col = "Inner " || split_cols[i];
	out_col = "Outer " || split_cols[i];
	dtt << new column(inn_col, Numeric, "Continuous", Format( "Best", 12 ));
	dtt << new column(out_col, Numeric, "Continuous", Format( "Best", 12 ));
for (i = 1, i <= nitems(nonsplit_cols), i++,
	one_col = nonsplit_cols[i];
	dtt << new column(one_col, Numeric, "Continuous", Format( "Best", 12 ));
dtt << Add Rows( nr/2 );
k = 0;
for (i = 1, i <= nr, i+=2,
	k++;
	for (m = 1, m <= nitems(split_cols), m++,
		one_col = split_cols[m];
		inn_col = "Inner " || split_cols[m];
		out_col = "Outer " || split_cols[m];
		column(dtt, inn_col)[k] = column(dt, one_col)[i];
		column(dtt, out_col)[k] = column(dt, one_col)[i+1];
	column(dtt, "Tire ID")[k] = column(dt, "Tire ID")[i];
	for (m = 1, m <= nitems(nonsplit_cols), m++,
		one_col = nonsplit_cols[m];
		column(dtt, one_col)[k] = column(dt, one_col)[i];
What you are asking for is available by using the Split platform
     Tables=>Split
After you open the Split platform, setup the screen as shown below
Once you click OK, it will create a new data table
The script to perform the Split is contained in the Source entry of the data table
Just right click on the word Source
and select Edit
The Edit window will open and show the JSL required to run the Split and create the data table you want.
Just cut and paste the JSL from the Edit window, into your script
pmroz
Nice Jim!  Much better than my brute force approach.  I would add uS and psi to the Group columns as per @Arocha1 's request.
