Reordering Column Not Working
The reorder columns function doesn't work in the column menu. Does anyone know a reason for this? Is this due to the data type or name?
M. Dereviankin
Re: Reordering Column Not Working
JMP does not allow the reordering of columns when the columns are grouped.  UnGroup the columns, then reorder, and then regroup.  This should give you what you want.
