Hi, I have jmp data coming from ATE and the columns have embedded spec limits, which sometimes make the data analysis difficult (limits are wide, so outliers are hiding etc)...I can remove the embedded limits one by one by going to column properties, but i am looking for a way to remove limits from multiple columns at the same time..
