twillkickers
Remove {" "} from the outside of a string
I am trying to extract a value out of a table using the following JSL:
::GlobalVariable= :Column[RowNumber]
However, my output for ::GlobalVariable has unwanted {" "} around it. How do I remove this/prevent this from happening? Thank you!
Re: Remove {" "} from the outside of a string
It appears that your column that you have nemed "Column" has list values saved in it.  That wouls account for the {} in your variable called ::GlobalVariable.  And that inside the list definition, there is a string element, which is where the "" are coming from.  I am assuming that you did not intend for the values within :Column to be this.  So I would look to see where the values are coming from, rather than trying to delete them after the fact.  But if that is not possible, I would use the Word function if the value has {""} imbedded in a string, or if it is actually being returned as a true list, then you can simply specify a subscript to get rid of the list component.
::GlobalVariable = word(1,:Column[RowNumber],"{}");
// or
::GlobalVariable = :Column[RowNumber][1];
9 REPLIES 9
// or
ENTHU
I am facing the same problem with slight variation. I combine 2 columns and get the values of resulting column as a list.
I then assign this list to a cell.When I do so,the output is {"100@boiling","0@melting"}.
I need to remove {" "}.How can I do this?
Below is my code-
//Combine temperature and process step columns to get test temperature
dtCombined = dtSorted << Combine Columns(
delimiter( "@" ),
Columns(
:Temperature,
:process
//Selected Columns are Indicator Columns( 1 ),
Column Name( "Process_Temperature" )
unique_vals = {};
unique_vals = Associative Array(dtSorted:Process_Temperature) << Get Keys;
Column(dtemplate,"Value")[30] = Char(unique_vals) ;
ENTHU
I am able to remove {} using the solution mentioned above.But I need to take the " " (quotes) out as well.
Any help is appreciated.
you can use the parse() funcction to do that:
x="zippy"; show(parse(x))
ENTHU
My list is {"100@boiling","0@melting"}.
I first used word function to remove {} which works fine.
But when I do parse(),I see an error -
Unexpected ",". Perhaps there is a missing ";" or ",".
Line 1 Column 7:
The remaining text that was ignored was
Since the data is in a data table, the following should work:
dt = New Table( "Untitled 8",
	Add Rows( 1 ),
	New Column( "Column 1",
		Character,
		"Nominal",
		Set Values( {"{\!"100@boiling\!",\!"0@melting\!"}"} )
dt << New Column( "converted", character );
dt:converted[1] = Word( 2, dt:column 1[1], "\!"" ) || "," ||
Word( 4, dt:column 1[1], "\!"" );
pmroz
It's a little cleaner with concat items.
New Table( "Test", Add Rows( 1 ),
	New Column( "Column 1", Character, "Nominal",
	New Column( "Column 2", Character, "Nominal",
		Formula(
			one_list = Eval( Parse( :Column 1 ) );
			Concat Items( one_list, "," );
pmroz
You can also use substitute to remove {} and ".
		Formula( Substitute( :Column 1, "{", "", "}", "", "\!"", "" ) ),
ENTHU
Thanks.This works!
