Hi @ron_horne
As far as I know, there is not an out-of-the-box method for suppressing the default hover label data, even with the Hover Label Editor options now available in JMP 15. The Hover Label Editor will let you add additional information (and graphics!) to the hover, but any variable used in a data graphing or decoration role (i.e., X , Y, Overlay, Color, and Size) will always be included in the hover.
EDIT:
After some prompting by @Mark_Bailey who was sure he saw a way to do this, I investigated further and there is indeed a way to do what you need. You'll use the "Gridlet" option in the hover label editor, where you have the option to modify existing labels by name. Here's how you would do it for your example using Big Class:
- Enter the Hover Label editor by right-clicking the graph > Hover Label > Hover Label Editor
- Select the Gridlet section on the left
- In the "Delete" tab (the first tab at the top) we may enter the name of the variables we would like to remove from the Hover Label. I'll enter "height" and click Add, and then "weight" and click Add. Do not quote these entries when entering them (even though they will appear quoted once added).
Your hover label will now show only the labeled column of Name:
I hope this helps, and thanks @Mark_Bailey for the correction!
@julian
