Archy
Remove line from Graph builder
Hello comunity,
I am writing you because i have a small question related a line which i woul like to remove from a graph that made by using the graph builder. The lines that i want to remove are in black color because there are two different types of data
Best regards
Re: Remove line from Graph builder
Hi @Archy ,
What version of JMP are you using?  In JMP 14, you can nest the Group X variable at top which will give you vertical lines as well as removing the bottom X axis line of showing the nesting. To nest the Group X variable, you can drag and drop to the right or to the left of the main variable (Left is nests main Group Variable within dragged variable, Right nests dragged variable within the main Group X variable).
Would this work for you?
Best,
Chris Kirchberg, M.S.2
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail: [email protected]
www.jmp.com
Something like this:
www.jmp.com
Archy
Thanks, it solved my problem
