Voizingu
Remove element from a list that contain elements from a second list in JSL
Removing elements from a list is well documented in the the JSL discussions but for some reason I cannot figure out how to do this:
I need to remove elements from a list if the elements CONTAIN string from another list (not exact match).
Example below: I am trying to remove all elements that contain "Cal" or "Blue"
Thanks in advance,
-Voiz
clear symbols();
Deletesymbols();
ChosenDataCol = {"Cal1", "Cal2", "Cal3", "Temp1", "Temp25", "Blue56", "Blue32", "Blue95"};
RemoveCol = {"Cal", "Blue"};
For (i=1,i<=N Items( RemoveCol ), i++,
	For (j=N Items (ChosenDataCol), j<=1, j--,
		If(contains(ChosenDataCol[j], Eval(RemoveCol[i]))==1,
			Remove from(ChosenDataCol, j)
show (ChosenDataCol);
Re: Remove element from a list that contain elements from a second list in JSL
You can also utilize For Each or Filter Each
vals = Filter Each({val1}, ChosenDataCol,
	res = Filter Each({val2}, RemoveCol,
		!Contains(val1, val2)
	N Items(res) == N Items(RemoveCol);
// ChosenDataCol = vals; // {"Temp1", "Temp25"}
You will also have to consider what N Items(res) == N Items(KeepCol); is doing. You can add extra print inside the loop to assist in figuring that out
ChosenDataCol = {"SiCal 1", "Ba Cal 2", "toCal 3", "Si Temp1", "bouTemp25", "CaBlue 56", "SiBlue 32", "Blue 95"};
KeepCol = {"Cal", "Blue"};
	res = Filter Each({val2}, KeepCol,
	show(res);
	N Items(res) != N Items(KeepCol);
Also if you can have situations where both Cal and Blue can appear in single string, you will need to utilize a bit different method
7 REPLIES 7
In your For() loop,
j<=1
should be
j>=1
clear symbols();
Deletesymbols();
	For (j=N Items (ChosenDataCol), j>=1, j--,
		If(contains(ChosenDataCol[j], RemoveCol[i])==1,
Voizingu
Hi Jim,
Ha yes, I missed that :)
The solution works BUT it seems that the contains() is not very robust: if the String to look is in the middle of the list element, it doesn't find it.
Do you know why?
The log of the script below gives:
ChosenDataCol = {"Si Cal 1", "Ba Cal 2", "toCal 3", "Temp 1", "Temp 25", "SiBlue 32"};
instead of
ChosenDataCol = {"Temp 1", "Temp 25"};
clear symbols();
Deletesymbols();
ChosenDataCol = {"Si Cal 1", "Ba Cal 2", "toCal 3", "Temp 1", "Temp 25", "Blue 56", "SiBlue 32", "Blue 95"};
Thanks
Please refer to my initial response JSL.
Contains( ChosenDataCol[j], Eval( RemoveCol[i] ) ) == 1
was changed to
which allows for the correct answer.  I am not sure why the Eval() is interfering with the Contains()
Voizingu
Hello Jarmo,
Thanks the Filter each () seems to do the trick, even with more intricate inputs (see below).
Ideally I need the options to filter ChosenDataCol with the 2 ways:
- Remove unwanted elements based on list of string (this method here, which works now) => RemoveCol
- Only keep elements based on list of string (the opposite of the method here)
I thought removing the "NOT" from "!Contains()" should do the trick but it returns an empty list { }.
Do you know why?
thanks
Remove elements <-- works well
// log : {"Si Temp1", "bouTemp25"}
Keep elements <-- doesn't work
// log : {}
	show(res);
Voizingu
Hello Jarmo,
The "show(res)" helped me understand the logic. I really have to use For Each () functions more :)
there was a missing "!" before Contains to make the script really work, but now my 2 functions work properly.
I will have to think about your last remark, not sure if that scenario exists!
Thanks again
Voiz
show(vals)
// vals = {"SiCal 1", "Ba Cal 2", "toCal 3", "CaBlue 56", "SiBlue 32", "Blue 95"};
