AdamChoen
window tabs with active lagend
my script creates a window with a new tab for every bivariate trend chart, my issue is that the legend is inactive.
my end goal is to be able to highlight legend groups in interactive HTML.
I tried to add a local data filter - and it did not work for me.
I also tried adding the same lagend distribution chart.
I love to get more ideas or insights on what I'm doing wrong.
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
NW = New Window( "new window", Text Box( "Creation Date: " || Substitute( Format( Today(), "ddMonyyyy h:m:s" ), "-", ":" ) ),  tb = tab Box() );
sex_list = Associative Array( :sex ) << Get Keys;
For( i = 1, i <= N items( sex_list ), i++,
	dt << Clear Row States;
	dt << Select Where( :sex == sex_list[i] ) << Invert Row Selection <<  Hide and Exclude;
	dt << clear select;
		// create trend chart with limits
		Biv = dt << Bivariate(
			Y( :height ),
			X( :weight ),
/*			By( :Var ),
			Local Data Filter(
			Mode( Include( 0 ) ),
			Add Filter( columns( :CHAMBER ), Display( :CHAMBER) )
				Dispatch(
					"Bivar Plot",
					FrameBox,
					{Frame Size( 1000, 300 ), Row Legend(
						name,
						Color( 1 ),
						Color Theme( "JMP Default"(1) ),
						Marker( 1 ),
						Marker Theme( "Standard" )
		Dis = dt << Distribution( Nominal Distribution( Column( :name ), Frequencies( 0 ) ) );
	tb  << Append( Char(Sex_list[i]) , H list box(Report( Dis ), Report( Biv )));
	Biv << Close window;
	Dis << Close window;
NW << save Interactive HTML( SaveDirectory || "new window.htm" ) << close window;
dt << close window;
Thanks, Adam
Re: window tabs with active lagend
You append only report to the new window and that isn't interactive (there are two "layers" in JMP platforms). You can get some interactivity by appending the platforms BUT legend won't be interactive
dt = Open("$SAMPLE_DATA/big class.jmp");
NW = New Window("new window",
	Text Box("Creation Date: " || Substitute(Format(Today(), "ddMonyyyy h:m:s"), "-", ":")),
	tb = Tab Box()
sex_list = Associative Array(:sex) << Get Keys;
For(i = 1, i <= N Items(sex_list), i++,
	dt << Select Where(:sex == sex_list[i]) << Invert Row Selection << Hide and Exclude;
	dt << clear select;
	biv_expr = Expr(dt << Bivariate(
		Y(:height),
		X(:weight),
			Dispatch({}, "Bivar Plot", FrameBox,
				{Frame Size(1000, 300), Row Legend(
					name,
					Color(1),
					Color Theme("JMP Default"(1)),
					Marker(1),
					Marker Theme("Standard")
	dist_expr = Expr(dt << Distribution(Automatic Recalc(1), Nominal Distribution(Column(:name), Frequencies(0))));
	tb << Append(
		Char(Sex_list[i]),
		H List Box(
			dist_expr,
			biv_expr
nw << Save Interactive HTML("$TEMP/deleteme.html");
Close(dt, no save);
Web("$TEMP/deleteme.html");
Write();
If you have JMP18 and use Graph Builder to create your scatterplot then I think you can get interactive legend with some small extra work (use marker row states and then use the same column as overlay/color in graph builder)
	tb = Tab Box()
	dt << clear select;
		Y(:height),
		X(:weight),
					name,
					Color(1),
					Marker(1),
	tb << Append(
		Char(Sex_list[i]),
		H List Box(
			dist_expr,
			biv_expr
Close(dt, no save);
Write();
