vinkane
Regex within a column loop formula
Trying in vain to have theis column formula execute correctly
For( i = 0, i < 10, i++,
Regex( :Source, :Words to Remove, "", global replace )
Ten words to remove from the source column and replaced with a null.
All help is appreciated
Phil_Brown
Re: Regex within a column loop formula
VinKane​ , a point of interest....since column formulas implicitly loop over all rows in a table, I've often used a little trick when I want to script JSL in a column formula. So you in your case, the column formula would look something like this:
PDB
The for loop needs to start at 1.  the regex function needs to work with a JSL variable, it can't use the column.  You might want to use a table variable to hold the list of words to delete rather than keeping them in a column.  the JSL could be a lot simpler...see second example.
example 1
New Table( "Untitled 1",  Add Rows( 10 ), New Column( "words to remove", Character, "Nominal",
      Set Values(
        {"aaa", "bbb", "ccc", "ddd", "eee", "fff", "ggg", "hhh", "iii", "jjj"}
  New Column( "source", Character, "Nominal",
      Set Values(
        {"the aaa is bbb and bbb ccc", "a aaa b bbb c ccc ccc", "b bbb c ccc", "",
  New Column( "redacted", Character, "Nominal",
      Formula(
        x = :source;
        For( i = 1, i <= 10, i++,
            x = Regex( x, :words to remove, "", GLOBALREPLACE ),
        x;
example 2
New Table( "Untitled 2",  Add Rows( 10 ),
  New Table Variable( "redactionlist", "aaa|bbb|ccc|ddd|eee|fff|ggg|hhh|iii|jjj" ),
      Set Values(
        "fred iii ralph bbb bbb", "a aaa b bbb", "", "", "", "", "", ""}
      Formula( Regex( :source, :redactionlist, "", GLOBALREPLACE ) )
vinkane
!Thanks, works like a charm
Phil_Brown
PDB
vinkane
Great suggestion and hint. As a newbee I'm trying to absorb all of this
Phil_Brown
VinKane​, my pleasure. I should add that this method is useful for relatively simple scripts/formula. As requirements grow, you eventually are better off doing everything in pure JSL, as column formulas can get a bit tedious to edit/maintain.
PDB
