hogi
Level XIII
Reformat Script - Protect some code?
Reformat Script in JSL Editor is very helpful to get the code with a formatted structure.
Often it helps to find bugs in the code and to keep the overview.
But sometimes, it's the opposite.
Is there a way to protect code in a specific area from being shuffled by Reformat Script?
dt << Recode Column(
	dt:name,
	{Map Value(
		_rcOrig,
		{"ALFRED", "A",
		 "ALICE", "A",
		 "AMY", "A",
		 "BARBARA", "A",
		 "CAROL", "A",
		 "CHRIS", "A",
		 "CLAY", "A",
		 "DANNY", "A",
		 "DAVID", "A",
		 "EDWARD", "A",
		 "ELIZABETH", "B",
		 "FREDERICK", "B",
		 "HENRY", "B",
		 "JACLYN", //missing
		 "JAMES", "B",
		 "JANE", "B",
		 "JEFFREY","B",
		 "JOE","B",
		 "JOHN", "B",
		 "JUDY", "B",
		 "KATIE", "B"
		Unmatched( _rcNow )
	Update Properties( 1 ),
	Target Column( :name )
Re: Reformat Script - Protection some code?
Select only part of your code and then reformat the script
hogi
Level XIII
You mean: don't select some code around the protection area such that the remaining code gets consistent, then trigger Reformat Script?
Unfortunately, doesn't seem to work :(
Jarmo's suggestion works well, however one has to reformat syntactically valid JSL
results in reformatting only the selected parts of the code
hogi
Level XIII
Hm, syntactically valid JSL code - reformat works if I delete the code in the (non-selected) protection area.
So, the remainder seems to be OK.
I think the actual problem is:
The two pieces of code - above and below the protection area have to be - separately -  syntactically valid JSL code.
i.e. the protection area has to be on highest level - e.g. a whole function.
another example:
Good catch.
There is a work around.  The
     Advanced=>Comment Block
does not change the structure of the code, it simply comments out a highlighted section of code.  If you Comment Block, then Reformat the JSL and then highlight and
     Advanced=?Uncomment Block
you will achieve your goal
