jan_solo
Reference lines won't show up on chart
Hi everyone,
I'm currently writing a script that, eventually, generates charts.  On these charts, I add 6 reference lines.  2 of them just won't show:
vlbCharts << Append(
		Control Chart Builder(
			Size(800, 500), // Chart size
			Show Two Shewhart Charts(0),
			Show Control Panel(0),
			Show Excluded Region(0),
			Show Limit Summaries(0),
			Show Capability(0),
			Variables(Subgroup(:BatchPrefix), Y(:Value)),
			Chart(
				Points(Statistic("Individual")),
				Limits(Sigma("Moving Range" ), Show Limits(0))
				Dispatch(
					"Control Chart Builder",
					OutlineBox,
					{Set Title(sProduct ||  ": " || sComponent)}
				), // Chart title
				Dispatch(
					"Value",
					ScaleBox,
					{Min(nMinValue), Max(nMaxValue), Inc(nTicks), Minor Ticks(0),
					Add Ref Line(nLSL, "Solid", "Medium Light Orange", "LSL", 1), // Not shown
					Add Ref Line(nUSL, "Solid", "Medium Light Orange", "USL", 1), // Not shown
					Add Ref Line(nLCL, "Solid", "Medium Dark Red", "LCL", 1),
					Add Ref Line(nUCL, "Solid", "Medium Dark Red", "UCL", 1),
					Add Ref Line(nLCL_Calc, "Solid", "Dark Blue", "LCL_Calc", 1),
					Add Ref Line(nUCL_Calc, "Solid", "Dark Blue", "UCL_Calc", 1)}
				Dispatch(
					"graph display 1 title",
					TextEditBox,
					{Set Text("")}),
				Dispatch(
					FrameBox,
					{DispatchSeg(Line Seg(1), {Line Color("Black")} )}
The problem is the label "LSL"  and "USL".  When I change these to something else (eg "US" and "LS"), the lines will be displayed:
Add Ref Line(nLSL, "Solid", "Medium Light Orange", "LS", 1), // shows on chart
Add Ref Line(nUSL, "Solid", "Medium Light Orange", "US", 1), // shows on chart
Is there any way I can actually use LSL and USL as labels?
Thanks,
Jan
pauldeen
Re: Reference lines won't show up on chart
This seems to be a bug in the control chart builder platform as it works manually but not in code. I can reproduce the issue on JMP 16 EA8 and have submitted a bug report.
gzmorgan0
@jan_solo
This is just a wild guess knowing how JMP labels reference lines. Specify your reference lines with names USL and LSL and add the message to your control chart object.
cc_obj << Show Spec Limits(1);
If that doesn't work, an alternative is shown in the JMP > Help > Scripting Index
dt = Open( "$SAMPLE_DATA/Reliability/GaAs Laser.jmp" );
obj = dt << Degradation(
	Y( :Current ),
	Time( :Hours ),
	Label( :Unit ),
	Set Upper Spec Limit( 7.5 )  //set the spec limits
obj << Show Spec Limits( 1 );
My fingers are crossed.
@gzmorgan0 is correct.  You need to add the following command to your CCB code.
USL and LSL are the names JMP uses when you have a spec limit column property.  Some users have requested that spec limit column properties not show by default in control charts.  This is how the platform turns those off and on.  You are using the same names JMP uses so,  you will therefore need to use the above command to see them.
