ptkguy
Reference lines with slope
JMP 9.0.2 on Windows XP
I'd like to add a reference line to a scatterplot (using Graph Builder), but I don't want the vertical or horizontal lines that are possible through the axis settings.  I could use a dummy column with the appropriate values, but I'm hoping there is a more elegant solution...
Jeff_Perkinson
You can add a Graphics Script to the graph and use the "Y Function()" function.
Just right-click on the graph and chose "Customize". In the Customize Graph dialog click the + button to add a script.
Then, in the Templates drop down menu, choose Y Function.
Then you can put the formula for your line in the Y Function template and get a line.
Jeff
-Jeff
Jeff_Perkinson
Jeff
-Jeff
