SpannerHead
Rect() Function
Can the Rect() function be a text box?  Alternatively, is there another function that can be used in a graph builder script to create a shape with text?
Slán
SpannerHead
Slán
SpannerHead
MathStatChem
Re: Rect() Function
New Window( "Example",
	Graph Box(
		Text Color( "red" );
		Text( Boxed, {50, 20}, "Boxed Text" );
Re: Rect() Function
Text() with boxed argument is the correct answer for this, but you can draw multiple elements on top of each other. Order does matter with this and you might have to do some adjustments to coordinates especially if you are using Text()
nw = New Window("Example",
	Graph Box(
		Pen Color("Black");
		Fill Color("LightGreen");
		Circle({20, 20}, 20, "FILL");
		Text Color("Black");
		Text(Center Justified, {20, 17}, "centered");
MathStatChem
Re: Rect() Function
	Graph Box(
Re: Rect() Function
	Graph Box(
		Pen Color("Black");
