Text() with boxed argument is the correct answer for this, but you can draw multiple elements on top of each other. Order does matter with this and you might have to do some adjustments to coordinates especially if you are using Text()
nw = New Window("Example",
Graph Box(
Pen Color("Black");
Fill Color("LightGreen");
Circle({20, 20}, 20, "FILL");
Text Color("Black");
Text(Center Justified, {20, 17}, "centered");
