lala
Level IX
Recently JMP often appear this error, is the computer memory failure?
Hello!
JMP often crashes during computation. This system error occurs:
What is the reason?
Re: Recently JMP often appear this error, is the computer memory failure?
Probably not a hardware problem. Tech support can help figure it out.
lala
Level IX
Thank Craige!
I still find it stable to use JMP 14 in Windows 7.
But I'm using the same JSL, working on the same structure file.This problem did not arise before.
I thought I recently tried to install win10, win11.In the end, it's all about reverting to win7 and using JMP 14.
