I need to load aCSV file which might be in number of different formats. And I need to find what line my data starts on. I know that the column names start after a certain line, let's say "[Data starts here]".
This is what I do:
ex = Load Text File(
filePath
words = Words( ex, "\!n\!r" );
headersLocation = Loc(words, "[Data starts here]");
and then I use headersLocation+1 to specify where my headers start.
The problem happens when I have an empty line in my CSV file:
line1
line2
[Data Starts Here]
Header1, header2
0,0
1,1
When I break this file into words, line "[Data STarts Here]" will be the third one, Loca() function will give me 3 in this case, while in reality it's 4th line.
So when breaking file by Words function - that empty line just doesn't make it into the list.
And I don't know how many empty lines I may have in the file before data starts.
How do I go about it?
I can break by either "\!n" or "\!r" only, and then use Left() or Right() in a for loop to remove the remaining special symbol, but it seems too brute force and not very optimal and I'm not sure it is correct. Something like this:
For Each( {value, index}, words, words[index] = Right(value, Length(value)-1););
The whole script being:
filePath
Then it seems to be working. But is this the best and even a correct solution?
