dale_lehman
need help identifying first nonzero column
I have a large dataset with around 30 columns of time-dated financial entries.  I want to know which column is the first with a nonzero (no columns have missing data, but I want to get the first column with a positive value entry) value.  I've attached a small made-up example with four time columns and a fifth column showing what I'd like my formula to result in.  If the zero values were missing, I could use the function for Number (number of nonmissing values) to get what I want, but when there is no missing data and zero values, I can't figure out how to automate identifying which column is the first that has a positive value.  Any ideas will be appreciated.
uday_guntupalli
Level VIII
Re: need help identifying first nonzero column
@dale_lehman,
Couple of thoughts and solutions here to your problem .
Approach 1 : Continue with JSL from previous solution and add it to table
dt = Current Data Table();
Mat = dt << Get As Matrix;
DesList = list();
for(i = 1 , i <= N Rows(Mat), i++,
		Pos = Min(Loc(Mat[i,0]));
		Insert Into(DesList,Pos);
dt << New Column("Test",Numeric,Continuous,<< Set Values(DesList));
// Please note that there will be "." missing value if none of your columns have a positive value
Approach 2 : Script the formula in JSL and apply it to the table - a little roundabout - but scaleable - an old but relevant example - will edit later in the day
for(i = 1, i <= N Items(InvColNames), i++,
							If(i == 1,
									Stmt = ":" || InvColNames[i] || " >= 1 &" || ":" || InvColNames[i] || " <= InvLimit" ;
									Stmt = Stmt || " & " || ":" || InvColNames[i] || ">= 1 &" || ":" || InvColNames[i] || " <= InvLimit"  ;
					Eval( Parse( Eval Insert("\[ dt_Inp << New Column("Status_Inv",Numeric,Continuous,Formula(^Stmt^)); ]\" ) ) );
Approach 3 :  Manually do something like this - not a fan of this, but can't seem to find an alternative by myself - maybe others will have better thoughts
If(
	:Column 1 > 0, "Column 1",
	:Column 2 > 0, "Column 2",
	"No Positive"
Best
Uday
uday_guntupalli
Level VIII
@dale_lehman,
Maybe try this ?
DesList = list();
Show(DesList);
Best
Uday
dale_lehman
Thank you - this indeed computes what I want, but I need a bit more help (due to my almost nonexistent JSL abilities).  I can see the correct calculations in the log window, but when I enter your script into the formula window for a new column, I get blank values.  The warning I get concerns the Show() function.  How do I get the resulting calculations to appear in the new formula column?
uday_guntupalli
Level VIII
@dale_lehman,
DesList = list();
							If(i == 1,
If(
	"No Positive"
Best
Uday
