dledom
Re: I am trying to build a Transfer Function
I am still having trouble building a transfer function.  I am using "Sales" as the output and "Inventory" as the input.  I don't have any missing values (represented by a dot in the data table) in my inventory column.  I build both functions and input as below:
Which produced the following error.
Any ideas?
Thanks
Jeff_Perkinson
This is going to be a difficult problem to diagnose without seeing your data. Can you share the data table that you're working with? (Make sure there's nothing proprietary in it before posting it.)
If you're not able to post a sample of the data that you're working with here, your best bet is to contact Tech Support and let them help.
-Jeff
-Jeff
dledom
Re: Re: I am trying to build a Transfer Function
Attached is the requested data table.
Thank you.
Sent: Wednesday, August 10, 2016 1:04 PM
To: Desta Ledom
Subject: Re: - I am trying to build a Transfer Function
JMP User Community
<https://community.jmp.com/?utm_source=JIVE&utm_medium=email&utm_campaign=System%20Email%20Tracking>
reply from Jeff Perkinson
<https://community.jmp.com/people/jeff.perkinson?et=watches.email.thread>
in Discussions - View the full discussion
<https://community.jmp.com/message/230171?et=watches.email.thread#230171>
If you delete the rows that have missing Sales and Inventory values (the ones that are hidden/excluded already), that will avoid the error message and fit the model.
-Michael
Michael Crotty
Sr Statistical Writer
JMP Development
dledom
That worked!  Thank you!
I've run into this before. You have some excluded rows with missing values. For some reason, you have to DELETE those rows. Then you should be able to build the transfer function.
dledom
Thank you for ending SEVERAL very frustrating months!  I can't believe that was the problem all this time!!
