Knekse
Random Normal Mixture vector input
Hi
I have been trying to write a formula for a column, using Random Normal Mixture(meanvec, sdvec, probvec). I would like to use Table variables as the input. How do I go about this? Do I define the table variables as vectors or can i make a vector of single table variables in the formula editor?
Thank you for any clues or help
ian_jmp
Level X
Re: Random Normal Mixture vector input
I think Jim was just using the script above as a convenient way to generate the table with the required properties and formula. But the script is not required. Please see the attached.
Here is an example script that uses table variables as input to a Random Normal Mixture formula:
dt = New Table( "Example" );
mv = [-3, 3];
sv = [1, 1];
pv = [.3, .7];
// All table variables are actually character strings
// so the matrices need to be saved as literals
dt << New Table Variable( "meanvec", Char( mv ) );
dt << New Table Variable( "sdvec", Char( sv ) );
dt << New Table Variable( "probvec", Char( pv ) );
dt << New Column( "Rand NM",
       set formula( Random Normal Mixture(
              Parse( dt:meanvec ),
              Parse( dt:sdvec ),
              Parse( dt:probvec ) ) )
dt << add rows( 1000 );
Knekse
Hi Jim
Thank you very much for the answer. I was actually looking for a solution for how to do it in the formula editor in a table, ie. without scripting. Do you know how that can be done?
Best regards
Jeppe
ian_jmp
Level X
Knekse
Thank you Ian... I was missing the Parse()​ function in there... Now I got it to work
