Justin_Bui
Randome sampling from a lognormal distribution shape
Hi all,
I have a distribution lognormal with bellow shape/scale parameter (made by 165 data)
Now I want to randome sampling with different sample size (5pcs, 10pcs...)
What I want is I expect when running more data it will still follow this distribution shape.
So I want to simulate what kind of data I will receive when sampling 5/ 10/20 samples in different times.
I expect each time will show abit different result just cause by sampling eror
Are there any way I can do it in Jmp
peng_liu
Re: Randome sampling from a lognormal distribution shape
If I understand your interest correctly, I think Simulate ( https://www.jmp.com/support/help/en/17.1/#page/jmp/simulate.shtml# ) is what you need.
The idea is so sub-sample from your data and fit Lognormal repeatedly and collect summary statistics. I attach a modified Big Class sample data to illustrate.
Run the script in the data table. It fits Lognormal to "weight" variable, but use "random freq" as Freq.
Now right click on a statistic of interest, and choose "Simulate":
In the dialog, choose "random freq" on both sides, click Ok:
And you will get a table like the following:
The last two columns are the summary statistics of individual fits to sub-samples.
The "random freq" column use "Resample Freq" function:
What you need to do is to tweak the threshold in the column formula, so you can get the total of 5/10/20 as you wish.
peng_liu
This example illustrates how you can use the parameter estimates for the distribution model to simulate new samples of different sizes.
Names Default to Here( 1 );
// role of arguments
nRows = 25;
nCols = 1;
μ = 1.038356;
σ = 0.7746626;
sample = J( nRows, nCols, Random Lognormal( μ, σ ) );
dt = New Table( "Sample from LogNormal Population",
	New Column( "Sample", "numeric", "Continuous", Values( sample ) )
dt << Distribution( Y( :Sample ) );
