jff
jff
Random Parameters in Profiler?
I am evaluating JMP (currently V. 7, but my company is in the upgrade process) and I am particularly interested in figuring out how to use the Profiler for some of my frequent activities. Can anyone help with the following?
I would like to simulate a function F(x, theta(i)) over a range of x values. Theta(i) is a set of parameters drawn from a multivariate-normal distribution for each individual "i".
If I specify the parameters as columns then each row is drawn as a new sample. As such I cannot simulate that instantiation of the distribution across the range of X.
If I use the profiler, it is not apparent to me whether I can specify a parameter as one of the simulator variables (e.g., where you have the choice to specify the type of distribution).
0 REPLIES 0
