  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Jackie_
Radio button on Graph builder to vary Variable Role("Y)
I want to create a RB where you can change three variables Resistance, Currents, Voltage using Radio buttons.
Here's what I have tried but something doesn't seem to be correct. Any advice?
stk = Current Data Table();
col = stk << Get Column Names( "String" );
Resist = {};
curr = {};
Volt = {};
For( i = 1, i <= N Items( col ), i++,
	If(
		Contains( col[i], "Resistance" ),
       Insert Into( Resist, col[i] ),
		Contains( col[i], "Currents" ),
		Insert Into( curr, col[i] ),
		Contains( col[i], "Voltage" ),
			Insert Into( Volt, col[i] ),
New Window( "",
	H List Box(
		V List Box(
			Radio Box(
				{"Resitance", "Currents", "Voltage"},
				<<SetFunction(
					Function( {neb},
						sel = neb << get selected;
						If(
							sel == "Resistance",
								For Each( {col, index}, Resit,
									obj << Remove Variables( N Items( obj << get variables() ), Role( "Y" ) );
									gb << add variables( col, Role( "Y" ), Position( index ) );
							sel == "Currents",
								For Each( {col, index}, curr,
									obj << Remove Variables( N Items( obj << get variables() ) );
							sel == "Voltage",
								For Each( {col, index}, Volt,
		V List Box(
			obj = stk << Graph Builder(
				Size( 518, 543 ),
				Variables(
					X( :Resistance A5, Combine( "Parallel Merged" ) ),
					X( :Resistance A6, Position( 1 ), Combine( "Parallel Merged" ) ),
					X( :Resistance A7, Position( 1 ), Combine( "Parallel Merged" ) ),
					X( :Resistance A8, Position( 1 ), Combine( "Parallel Merged" ) ),
					X( :Resistance A9, Position( 1 ), Combine( "Parallel Merged" ) ),
					X( :Resistance A10, Position( 1 ), Combine( "Parallel Merged" ) ),
					X( :Resistance A11, Position( 1 ), Combine( "Parallel Merged" ) )
				Elements(
					Box Plot( X( 1 ), X( 2 ), X( 3 ), X( 4 ), X( 5 ), Legend( 2 ) ),
					Histogram( X( 1 ), X( 2 ), X( 3 ), X( 4 ), X( 5 ), Legend( 3 ) )
			gb = Report( obj )[Graph Builder Box( 1 )];
			obj << Parallel Axis Merging( "High Similarity" );
 Thanks,
Jackie
Re: Radio button on Graph builder to vary Variable Role("Y)
I made quite a lot of small changes, fixing typos and so on
stk = Open("$DOWNLOADS/datatable.jmp");
col = stk << Get Column Names("String");
Resist = {};
curr = {};
Volt = {};
For(i = 1, i <= N Items(col), i++,
	If(
		Contains(col[i], "Resistance"), Insert Into(Resist, col[i]),
		Contains(col[i], "Currents"), Insert Into(curr, col[i]),
		Contains(col[i], "Voltage"), Insert Into(Volt, col[i]),
		show("?");
nw = New Window("",
	H List Box(
		V List Box(
			Radio Box(
				<<SetFunction(
					Function({neb},
						While(N Items(obj << get variables()),
							obj << Remove Variable(1)
						If(sel == "Resitance",
							For Each({col, index}, Resist,
								Eval(EvalExpr(
									gb << add variable({Expr(Column(col)), Role("X"), Position(1), Combine("Parallel Merged")});
						, sel == "Currents",
							For Each({col, index}, curr,
								Eval(EvalExpr(
						,sel == "Voltage",
							For Each({col, index}, Volt,
								Eval(EvalExpr(
		V List Box(
				Size(518, 543),
				Show Control Panel(0),
				Variables(
					X(:Resistance A5, Combine("Parallel Merged")),
					X(:Resistance A6, Position(1), Combine("Parallel Merged")),
					X(:Resistance A7, Position(1), Combine("Parallel Merged")),
					X(:Resistance A8, Position(1), Combine("Parallel Merged")),
					X(:Resistance A9, Position(1), Combine("Parallel Merged")),
					X(:Resistance A10, Position(1), Combine("Parallel Merged")),
					X(:Resistance A11, Position(1), Combine("Parallel Merged"))
				Elements(
					Box Plot(X(1), X(2), X(3), X(4), X(5), Legend(2)),
					Histogram(X(1), X(2), X(3), X(4), X(5), Legend(3))
			gb = Report(obj)[Graph Builder Box(1)];
			obj << Parallel Axis Merging("High Similarity");
Resist = {};
curr = {};
Volt = {};
	If(
		show("?");
nw = New Window("",
	H List Box(
		V List Box(
			Radio Box(
				<<SetFunction(
					Function({neb},
								Eval(EvalExpr(
								Eval(EvalExpr(
						,sel == "Voltage",
								Eval(EvalExpr(
		V List Box(
				Size(518, 543),
				Variables(
				Elements(
Jackie_
Thanks @jthi. I noticed that the elements in the graph builder change after varying the RB. Is there a way I can retain the elements settings to box plot and histogram?
Elements( Box Plot( X( 1 ), X( 2 ), X( 3 ), X( 4 ), Legend( 2 ) ), Histogram( X( 1 ), X( 2 ), X( 3 ), X( 4 ), Legend( 3 ) ) )
Depending on which options are changing easiest option might be to rebuild the Graph Builder when radio box option is changed. The format is fairly simple for this graph builder and creating expression/function for it isn't too bad ( Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute is most likely needed for it)
Jackie_
@jthi Thanks. I looked at the discussion but little confused. You mind sharing an example for reference?
