Is it possible to add reference line with the same value using JSL?
Aug 24, 2023 09:08 PM(2250 views)
Hi all, I'm quite new to JMP. I'm writing a script in JSL, I have two high limits and some of the values are the same value. Is it possible to add reference lines with the same value in JMP? Currently, I'm using JMP Pro 14.3.0. Thank you.
