d_barnett
RGB Values to Color Names in Data Table
I have a data table that contains RGB values in separate columns and I want to have the name of the color ( or close to it) displayed in a seperate column.
One problem is that I can give some leeway in the values so they could be in a range of values so Black could be 0-0-0 or 5-0-0 or 0-5-0 or 0-0-5 or 5-5-0 to 5-5-5 etc. so a range of +/- 5 either side would be allowable
e.g.
Color NameRGB CODERGB
Black0-0-0000
Blue0-0-25500255
Light Blue173-216-230173216230
Yellow255-255-02552550
Orange255-165-02551650
Deep Pink255-20-14725520147
Pink255-192-203255192203
Brown165-42-421654242
ms
Super User (Alumni) ms
Re: RGB Values to Color Names in Data Table
Nice example!
Here is an attempt to adapt John's script into a column formula:
Current Data Table() << New Column( "Color Name2",
  formula(
  Local(
  {colornames = {"Black", "Blue", "LightBlue", "Yellow", "Orange", "DeepPink", "Pink", "Brown"},
  rgb = [0 0 0,
  0 0 255,
  173 216 230,
  255 255 0,
  255 165 0,
  255 20 147,
  255 192 203,
  165 42 42]},
  colornames[Loc Min( V Sum( (rgb - Matrix( Repeat( {{:Red, :Green, :Blue}}, 8 ) ))` ^ 2 ) )]
10 REPLIES 10
d_barnett
I realised I probably didn't give enough information in the question. I have a table which contains the R,G & B values for a color from image analysis of a sample, I want JMP to 'translate' these into the nearest color name and put this into a separate column.
e.g. the output I have is similar to this
sampleRedGreenBlue
11654044
2136150102
3124160167
4124160158
5208254228
6202252226
7122158163
8118153153
9209254226
10210254234
11206253225
12202251223
13209254226
14211254233
15165192154
I want JMP to look through these values and tell me the nearest color, from either a different table containing a list of colors or from within a script.
So row 1 would say Brown, even though this doesn't exactly match the RGB for brown in the first table.
louv
Staff (Retired)
Would something like this work?
With some scripting help from melaniedrake,  I created and uploaded a script that finds the closes color and puts it in a column named "Color Name". RGB Color Matching Script. I hope it helps.
d_barnett
John,
I really like the look of this answer but unfortunately I can't access the document you've put on here. It comes up with unauthorised access.
Could you please post it here so I can get it please?
Regards
David
Jeff_Perkinson
Try the link in John's post again. I think it just hadn't been moderated yet.
It's available now.
-Jeff
-Jeff
Thanks Jeff.
Maybe I should have tried to attached the script directly here.
Sorry for the delay David. Please let me know if you have any questions about the code.
~John
Hi ,
Can any one comment on how to get the color names for Color themes. e.g JMP Dark. how to get there color names and corresponding colors?
Thanks
Ram
Craige_Hales
Not sure if this is what you mean...you can retrieve the RGB for the jmp named colors like this:
Color To RGB( "Dark Red" );
{0.627450980392157, 0.0352941176470588, 0.133333333333333}
You can also try Color To HLS.  The RGB numbers between 0 and 1 could be multiplied by 255 if you need numbers between 0 and 255.  0 is black.  The three numbers from Color To RGB are the red, green, and blue parts.
Craige
ms
Nice example!
  formula(
  Local(
  rgb = [0 0 0,
  0 0 255,
  173 216 230,
  255 255 0,
  255 165 0,
  255 20 147,
  255 192 203,
  165 42 42]},
