R integration crashing
I've been running R integration specifically for making graphics with ggplot. Today of a sudden I started getting this error:
The request could not be completed because the R child process terminated unexpectedly with exit status 0xc0000409.
Send data for "dt" failed
I can still send data to R with other add ins that I've created, but something is happening specifically only with ggplot graphics.
M. Dereviankin
Craige_Hales
Re: R integration crashing
Might be worth examining the 'dt' table to see if it looks reasonable. (I'm guessing. Never used R.)
Craige
ih
Super User (Alumni) ih
It looks like that exit code is normally from a stack overflow. I concur with @Craige_Hales that examining dt is a good place to start.  You might follow that by sending a smaller version of dt to R, and by running each line of the R script separately, or gradually add lines to your script, until you find the exact line that causes the error.
