AHM
AHM
Questions about DOE
Hi everone
I would like to conduct a field trial. I would like to check the response of a new fertilizer (at different levels) with and without exisiting fertilizers on yield of wheat.
i need help with DOE. so basically i have eight treatments T0= negative control (no fertlizers), T1= positive control (NPK) business as usual fertlizers, T2= NPK+low level of new fertilizer, T3=NPK+medium level of new fertlizer, T4=NPK+high level of new fertilizer, T5=low level of new fertlizer, T6=medium level of new fertilizer, T7=high level of new fertilzier.
i need to check the effect of treatments on yield. i have planned 3 replicates or blocks (Randomised complete block design).
how can i use DOE to design this trial in JMP.
I shall welcome all the suggestions.
Thanks
Victor_G
Re: Questions about DOE
Hi @AHM,
Welcome in the Community !
Regarding the treatments you would like to have, why not considering a DoE with two factors :
  • X1 : Quantity of NPK (with levels at 0 and at "normal/standard" quantity), numeric continuous factor
  • X2 : Quantity of new fertilizer (with levels at 0, middle level and high level), numeric continuous factor.
Using a standard factorial approach, and specifying a model with the two main effects, a quadratic effect for X2 to have experimental runs with 3 possible levels ( if you want to have 4 levels for factor X2 : absence, low, middle and high levels you can specify a cubic order effect term in addition in the model) and the interaction between these two factors, you should have all the treatments you are expecting :
You can create this Custom Design with this script (you can modify the quantity levels used, I just used them for illustration):
DOE(
	Custom Design,
	{Add Response( Maximize, "Y", ., ., . ),
	Add Factor( Continuous, 0, 5, "NPK Quantity", 0 ),
	Add Factor( Continuous, 0, 10, "New fertilizer quantity", 0 ),
	Set Random Seed( 14871954 ), Number of Starts( 312796 ), Add Term( {1, 0} ),
	Add Term( {1, 1} ), Add Term( {2, 1} ), Add Term( {2, 2} ),
	Add Alias Term( {1, 1}, {2, 1} ), Set Sample Size( 8 ), Simulate Responses( 0 ),
	Save X Matrix( 0 ), Make Design}
And datatable of the DoE (without replicates) is attached.
If you want to replicate the whole design 2 more times, you can use the "Augment Design" platform (in menu "DoE", "Augment Design"), click on "Replicate" option and specify 3 as the number of replicates :
You'll end up with a completely randomized design with 3 replicates, for a total of 24 runs (datatable attached).
If you have constraints about number of runs done per day for example, you can use blocks in the initial design generation, by adding a factor (type blocking) and specify the number of runs per block :
You can then specify the same model as before (with added block effect), the number of runs in total (24), and you'll end up with a design in 3 blocks (see datatable attached).
I hope these design options may help you in the creation of your DoE,
Victor GUILLER
AHM
AHM
Thanks a lot @Victor_G
As i am new to jmp and statistical world here please do apologize my stupid questions
1. I can rephrase my question again
Factor 1 (NPK) (2 levels)= 0, NPK
Factor 2 (GHQ) (4 levels)= 0, 5, 10, 50
Replications = 3
Treatments
T0= control (no fertlizers)
T1= control (NPK),
T2= NPK+5GHQ
T3=NPK+10GHQ
T4=NPK+50GHQ
T5=5 GHQ
T6=10 GHQ
T7=50 GHQ
I wish to have RCBD which will give me treatment * replication = 8*3 = 24 plots
Can you please help a DOE for this setup? Please suggest a script to run
for attached files you have sent, how can i go to their scripts if i want to edit them?
Looking forward for your kind response
Victor_G
With your informations, here is how the setting of the factors and model can be done in order to get the 8 treatments you need :
To obtain this 8-runs design, here is the script :
DOE(
	Custom Design,
	Add Factor( Categorical, {"0", "NPK"}, "NPK", 0 ),
	Add Factor( Discrete Numeric, {0, 5, 10, 50}, "GHQ", 0 ),
	Set Random Seed( 1540555554 ), Number of Starts( 329553 ), Add Term( {1, 0} ),
	Add Term( {1, 1} ), Add Term( {2, 1} ), Add Term( {2, 2} ), Add Term( {2, 3} ),
	Add Term( {1, 1}, {2, 1} ), Set Sample Size( 8 ), Simulate Responses( 0 ),
Then, to have 3 replicates, you just need to use this design and go to "Augment Design", option "Replicate", specify that you want each runs done 3 times, and you'll obtain your 24 runs as needed (datatable attached). The script used to augment the design is :
dt2 = dt << run script( "Original Data Table" );
Current Data Table( dt2 );
DOE(
	Augment Design,
	X( :NPK, :GHQ ),
	Y( :Y ),
	{Augment Method( Replicate, 3 ), Save X Matrix( 0 ), Simulate Responses( 0 ),
	Make Table}
Note that you can find these scripts and modify them in every DOE datatable, by right-clicking on the green triangle next to "DOE Dialog" and then clicking on "Edit". This will open a windows with the script used to generate the design.
Victor GUILLER
