DNAFoundry
Pull SQLite data into JMP
I have my data stored in an sqlite database and would like to pull it into JMP and merge with my DOE design.
My jmp file looks like this:
keyVariable1variable2variable3
1---
2---
My SQL database has the columns like this:
keydata_typeresult
1Variable112.6
1Variable215.4
1Variable317.8
2Variable18.2
2Variable27.1
2Variable37.2
I would like a query to bring in the data to jmp like this:
jmptable:
112.615.417.8
28.27.17.2
I have set up the SQL connection and that is working fine. So what I would like to do is join the tables and transpose the data into the correct variable columns. Any idea how to do this?
Thanks
Re: Pull SQLite data into JMP
All you need to do, is after you have initially read in your table from your SQlite database is to then Split the data into a new table
     Tables==>Split
Specify data_type as the Split By value
Specify Result as the Split Columns
     Tables==>Split
DNAFoundry
Great this works, thanks!
