MichaH
Proper labels without stacking
how can I get proper labels for data without stacking. I cannot stack as I need to see rows dependencies, but on the other hand side need to have for each category only relevant data. I attached also the file.
Re: Proper labels without stacking
Here is a script which should create the graph (mostly, it doesn't fix legend)
dt = Open("$DOWNLOADS/Points.jmp");
dt << Clear Row States; // to remove labels
new_col = dt << New Column("Row", Numeric, Ordinal, Formula(Row()));
new_col << Suppress Eval(1);
gb = dt << Graph Builder(
	Size(1076, 744),
	Show Control Panel(0),
	Variables(Y(:VA), Y(:WA), Group X(:Type), Overlay(:Row)),
	Elements(
		Position(1, 1),
		Box Plot(Y, Overlay(0), Legend(8)),
		Points(Y, Overlay(0), Legend(10)),
		Bar(Y, Legend(12), Bar Style("Float"), Label("Label by Value"))
	Elements(
		Position(1, 2),
		Box Plot(Y, Overlay(0), Legend(9)),
		Points(Y, Overlay(0), Legend(11)),
		Bar(Y, Legend(13), Bar Style("Float"), Label("Label by Value"))
		Dispatch(
			"Graph Builder",
			FrameBox,
			{DispatchSeg(BarSeg(1), {Set Width Proportion(0.00005)})}
		Dispatch(
			"Graph Builder",
			FrameBox(2),
			{DispatchSeg(BarSeg(1), {Set Width Proportion(0.000001)})}
		Dispatch(
			"Graph Builder",
			FrameBox(3),
		Dispatch(
			"Graph Builder",
			FrameBox(4),
		Dispatch(
			"Graph Builder",
			FrameBox(5),
		Dispatch(
			"Graph Builder",
			FrameBox(6),
		Dispatch(
			"400",
			LegendBox,
			{Legend Position(
				{8, [0, -3], 10, [2], 12, [4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18,
				19, 20, 21, 22, 23, 24, 25, 26], 9, [1, -3], 11, [3], 13, [-3, -3, -3, -3, -3,
				-3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3, -3]}
Important things are setting variables for graph builder
and customizing each bar segments width proportion to be much smaller
and you end up with
and if you need classification I would maybe consider modifying the marker
7 REPLIES 7
What are "proper labels" in this case?
MichaH
Hi, please see attached.
MichaH
See here stacked...
One option is to add new column which has the row numbers and then use that as overlay for float type of bar charts and enable labels on those. Then use customize to make those "bar charts" smaller and hide extra values from legend. (This is is very annoying to do though)
MichaH
Hi, can you please show me how please?
	Size(1076, 744),
	Elements(
		Position(1, 1),
	Elements(
		Position(1, 2),
		Dispatch(
			"Graph Builder",
			FrameBox,
		Dispatch(
			"Graph Builder",
			FrameBox(2),
		Dispatch(
			"Graph Builder",
			FrameBox(3),
		Dispatch(
			"Graph Builder",
			FrameBox(4),
		Dispatch(
			"Graph Builder",
			FrameBox(5),
		Dispatch(
			"Graph Builder",
			FrameBox(6),
		Dispatch(
			"400",
			LegendBox,
			{Legend Position(
and you end up with
MichaH
Thank you a lot despite I was not able to replicate.
