It isn't a good idea to have a target meeting the USL or LSL level exactly, ideally the target sits between the two. Your settings are far away from where you have set your spec limits. The real question to ask now is - are your spec limits appropriate for your conditions? How have you decided your spec limits? Is it something strictly set as a critical quality marker that your results have to fall within - if so then you may want to investigate why your responses aren't achieving those targets.
I think you had best review your process and get a better understanding of applying the SPC, there are some good resources here and here. I would also suggest looking at some of the other platforms in JMP like the distribution platform to show a quick overview of what your responses are vs. the limits you are setting.
Hope that helps!
Thanks,
Ben
