Using JSL Script to Get Spec Limits from Column
I am using JMP 18.1.0. I am trying to find if there is a way I can get the "Spec Limit" property of a column, and then be able to manipulate the LSL or USL as a number. Below is some example code and the resulting Log messages. The LSL and USL outputs from Get Property don't seem to be in a usable state. The commented out line is what I would like to do, math functions or comparison with the LSL/USL to any other number.
//Example Code
dt = Current Data Table();
y = :"Test Column"n << Get Property("Spec Limits");
Show(:"Test Column"n[1]);
Show(y);
Show(y[2]);
//Show(:"Test Column"n[1] - y[2])
Log Output Messages:
  • :Test Column[1] = 0.5;
  • y = {LSL(0), USL(1), Show Limits(1)};
  • y[2] = USL(1);
Is there any way to get the LSL and USL from the Spec Limits property as a number?
Re: Using JSL Script to Get Spec Limits from Column
Here is a simple example of extracting the LSL from a column property and assigning it to a memory variable
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
specs = dt:npn1 << get property( "spec Limits" );
LSL = specs["LSL"];
LSL = specs["LSL"];
