mylifemyrule
Process Capability by group
hi,
May I know where is wrong in the scrip I would like to generate the process capability report by lot_id as below.
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
// Create a complex name for a column to make sure it will be
// processed correctly
dt:NPN1 << set name( "NPN1-7/Best" );
// Get a list of columns to be used
colList = dt << get column names( continuous, string );
ProcessFunc = Function( {TheList},
	// Move them into a single literal string of the format required
	// for the Process Variables element in the Process Capability
	// platform
	TheVars = ":Name(\!"" || TheList[1] || "\!")";
	For( i = 2, i <= 10, i++,
		TheVars = TheVars || "," || ":Name(\!"" || TheList[i] || "\!")"
	// Run the Process Capability platform, using the literal
	// string "TheVars"
      pcVar=Eval(Parse("dt << Process Capability(
      SendToByGroup( Bygroup Default ),
	Process Variables( "|| TheVars|| ")
	{:TheVars << Process Capability Analysis},
	By( :lot_id )
	Goal Plot( 0 ), Capability Index Plot( 0 ) ),
	 pcVar <<Order By( "Within Sigma Cpk Ascending" );
	 pcVar <<Order By( "Overall Sigma Ppk Ascending" );
	 pcVar <<Overall Sigma Summary Report( 1 ),
	 pcVar << Within Sigma Summary Report( 1 )
Return = ProcessFunc( colList );
WebDesignesCrow
Re: Process Capability by group
you have double comma.
	By( :lot_id )
mylifemyrule
it's doesn't work.
Which version of JMP are you using? Is there a specific reason for building the message using strings instead of expression (Eval(Parse()) vs Eval(Substitute()) vs Eval(EvalExpr())? Have you checked that the string you are building is correct?
