Biominer_17
Problem with the new built-in UMAP feature
Hi, I've testing both t-SNE and UMAP embedding features in Jmp Pro 17.1 release. t-SNE performs flawlessly, but UMAP just makes the program closes inmediatly as I run the analysis. Jmp closes suddenly without any error prompt or log, no matter the number of samples analyzed (50, 100, 300, etc) or settled parameters. I actually use the MNIST sample data provided in the former UMAP ADD-in dependent on R. Why does it happen? And how can I fix it? Thanks in advance
Re: Problem with the new built-in UMAP feature
Hi @Biominer_17 ! Thank you for the question! There is a quick solution for this:
on the Multivariate Embedding platform, click UMAP Options, then you will be able to see a set of UMAP-specific parameters. Please check if the parameter "Local Connectivity" has a missing value . there. You could specify the number 1 for "Local Connectivity". Just like the screenshot below.
Please let me know if you still encounter errors/crashes after trying this.
Thank you, @Victor_G and @Jeff_Perkinson ! This issue is fixed for JMP PRO 17.2.
6 REPLIES 6
Victor_G
Hi @Biominer_17,
Welcome in the Community !
I tried to reproduce the same analysis on the same dataset (attached) with JMP PRO 17.1, and I got the same results as yours with UMAP : calculations are in progress, and then everything is closed.
Can someone from JMP look at this technical bug ? @MJ ?
In the meantime, I didn't try it, but an add-in has been created in 2019 by @MJ  to realize t-SNE and UMAP, perhaps the add-in will be more "robust" and reliable : Data visualization with t-SNE and UMAP
Victor GUILLER
Biominer_17
Indeed, I've used the ADD-in many times and worked well. Nevertheless I'm unable to run a R environment in this machine, so I tried the new built-in UMAP to perform some analysis. Thanks for your kindness
Jeff_Perkinson
I’m sorry to hear that you’re experiencing this crash. Please reach out to Tech Support ([email protected]) to ensure this is fully investigated and reported to our development team for correction in a future version.
-Jeff
Biominer_17
Many thanks for the suggestion
Biominer_17
Now the issue is gone. For some reason I've omitted that parameter, setting it to 1 has solved the problem. Many thanks to all for your kindness and attention. Thanks for an efficient and quick solution
