lrmc_may
Problem with Opening file (tried to make it a flexible dt name in JSL)
//Open Data Table: Recovery_Analysis:Plate Name.jmp
Recovery_Analysis:Plate Name = Open("MY FILEPATH");
//Split data table
Recovery_Analysis:Plate Name << Split(
	Split By(:Chemistry),
	Split(:Concentration),
	Group(:Well Id),
	Output Table("Untitled 17.jmp"),
	Sort by Column Property
//Save data table: Recovery_Analysis:Plate Name.jmp
Recovery_Analysis:Plate Name << Save("MY FILEPATH");
Re: Problem with Opening file (tried to make it a flexible dt name in JSL)
What type of problem are you facing?
lrmc_may
Hi, im facing an Error message in the very first line with Open.. (sry im a beginner)
lrmc_may
i just replaced "MY FILE PATH" in here to not post my actual file path
What type of error message? Something like:
"The namespace "Recovery_Analysis" is not defined in access or evaluation of 'Recovery_Analysis:Plate Name' , Recovery_Analysis:Plate Name"
Most likely you don't need to use namespaces (the part before your table name) and something like this would be enough
dt = Open("C:\Program Files\SAS\JMPPRO\16\Samples\Data\Big Class.jmp");
dt = Open("MY FILEPATH");
dt_split = dt << Split(
	Group(:Well Id),
	Output Table("Split table"),
dt_split << Save("MY FILEPATH FOR SPLIT TABLE");
be careful to not overwrite your non-split table
