lala
Level IX
After generating a new script in a data table through JSL, why does the operation behind the original JSL stop?
For example the following JSL
Does it finish adding scripts and then stop working?
Thanks!
Eval(
	Parse(
		"dt<<new script(\!"test\!",
dt<<Select Columns(ncol(dt));dt<<Move Selected Columns(after(Column(1)));
New Column( "AA" );
Re: After generating a new script in a data table through JSL, why does the operation behind the original JSL stop?
There is a syntax error in the JSL.  The Log shows
Unexpected end of input. Perhaps there is a missing "," or ")".
Trying to parse arguments of function "new script".
Line 2 Column 75: …olumns(after(Column(1)));►
The issue is a missing closing ");) for the New Script() function.  If the closing ");" is added the JSL works as expected.
Eval(Parse(
dt<<Select Columns(ncol(dt));dt<<Move Selected Columns(after(Column(1))););
dt << New Column( "AA" );
lala
Level IX
Eval(Parse(
Thank Jim!
