Hi, all
I had face a very simple problem which is create the column.
When I single run the below code, it come out this error in the log
Try(dt_firstseq_summary << Delete Column( "Percent" ) );
dt_firstseq_summary << New Column( "Percent",
Numeric,
Continuous,
Format( "Best", 8 ),
Formula( :Name("Total_Tested") / Col Sum(:Total_Tested) )
dt_firstseq_summary :name( "Percent" ) << Delete formula;
Error:
Send Expects Scriptable Object in access or evaluation of 'Send' , dt_firstseq_summary << /*###*/New Column( "Percent",
Numeric,
Continuous,
Formula( :Total_Tested / Col Sum( :Total_Tested ) )
In the following script, error marked by /*###*/
Try( dt_firstseq_summary << Delete Column( "Percent" ) );
Numeric,
Continuous,
dt_firstseq_summary:Percent << Delete formula;
But when I run my whole program, it able to create the column in data table, but the percent column cannot calculate the value.See photo below:
Error:
Column Percent Formula Interrupted
Name Unresolved: Total_Tested 1 times At rows: 2 Operation: Total_Tested, :Total_Tested/*###*/
Formula evaluation errors have been ignored
May I know how to fix it?
Any answer is appreciate.
Thanks.
