blue1994
Problem of create column
Hi, all
I had face a very simple problem which is create the column.
When I single run the below code, it come out this error in the log
Try(dt_firstseq_summary << Delete Column( "Percent" ) );
dt_firstseq_summary << New Column( "Percent",
	Numeric,
	Continuous,
	Format( "Best", 8 ),
	Formula( :Name("Total_Tested") / Col Sum(:Total_Tested) )
dt_firstseq_summary :name( "Percent" ) << Delete formula;
Error:
Send Expects Scriptable Object in access or evaluation of 'Send' , dt_firstseq_summary << /*###*/New Column( "Percent",
Numeric,
Continuous,
Formula( :Total_Tested / Col Sum( :Total_Tested ) )
In the following script, error marked by /*###*/
Try( dt_firstseq_summary << Delete Column( "Percent" ) );
Numeric,
Continuous,
dt_firstseq_summary:Percent << Delete formula;
But when I run my whole program, it able to create the column in data table, but the percent column cannot calculate the value.See photo below:
Error:
Column Percent Formula Interrupted
Name Unresolved: Total_Tested 1 times At rows: 2 Operation: Total_Tested, :Total_Tested/*###*/
Formula evaluation errors have been ignored
May I know how to fix it?
Any answer is appreciate.
Thanks.
Re: Problem of create column
Save the data table reference that is returned from the join operation. Then use it to send messages to create the new column  that you want. Like this:
dt_joined = dt_firstseq_summary << Join(
	With(dt_final_summary),
	Select( :S_B_Name, :N Rows, :Name( "Percent" ) ),
	SelectWith( :S_B_Name, :N Rows, :Name( "Percent" ) ),
	By Matching Columns( :S_B_Name = :S_B_Name ),
	Preserve Main Table Order();
	Output Table Name("Combined Table");
dt_joined << New Column( ... ):
Is it possible that your summary table is still linked to the raw data table and that is causing your issue?
I tried your code with a mocked up version of your data table and had no issue with the code.
blue1994
Hi, Jim
Yes, the summary table will linked with raw data table.
I will try again.
Thanks for help.
blue1994
Hi, everyone
I now able to join the 2 data table together into one data table.(combined data table)
But now my problem is how to create another new column into the combined data table?
This is my join script to join 2 data table together:
Thanks.
