Level XII
Prioritization of Yield Detractors
Besides the question is in spec(value) --- for a single parameter.
If there are several parameters with spec limits there could be sets  with multiple spec violation (fail A, fail A+B , fail A + K ... fail K, pass) ... is there a possibility to define a prioritization of yield detractors in JMP?
device 1 failed due to spec A - subsequent spec's do not have to be tested anymore.
->  In total x% of the devices fail due to (prioritized) spec A.
device 2 failed due to spec K - subsequent spec's do not have to be tested anymore.
-> In total x% of the devices fail due to less prioritized spec K - but no higher-prio spec.
device 3 fulfills all specs -> pass.
13 REPLIES 13
Re: Prioritization of Yield Detractors
Thanks. True...Distribution does give some nice ways at looking at things (and one can still add a filter(s)). I was thinking Graph builder incase there were other ways one might want to slice up the graph like by lot or other fab or other characteristic of the unit(s) bringing explored
Chris Kirchberg, M.S.2
www.jmp.com
Level XII
Distribution?
-> Graph Builder - but with the Histogram Option instead of bar graphs.
That is an option and also allows one to make their own graph from that.  Still looking for a better way to display graphs and how to surface the Manage Limits window in an intelligent way then go back to main window.  Also to add option to use column property of priority, but that may be in a revision.
www.jmp.com
What do you mean by "to surface the Manage Limits window in an intelligent way then go back to main window"?
