  • JMP will suspend normal business operations for our Winter Holiday beginning on Wednesday, December 24, 2025, at 5:00 p.m. ET (2:00 p.m. ET for JMP Accounts Receivable).
    Regular business hours will resume at 9:00 a.m. EST on Friday, January 2, 2026.
tsandidge
Print JMP version and details in jsl
I came up with a simple manual way to get the current version (not including the revision, e.g. 12 vs 12.2.0) of JMP for my scripts which send emails:<br>
<pre><code>version = word(-1,Get Path Variable("HOME"),"/");</code><pre><br>
This obviously returns:<br>
<pre><code>12</code></pre><br>
I was curious to see if anyone knew of a built-in method to get this as well as at least the revision, but possibly more. I would like to get:<br>
<pre><code>12.2.0</code></pre><br>
and possibly any of the information kept with the license:<br>
<pre>JMP® Pro  12.2.0 (64-bit)<br>
User:  *******<br>
Administrator:  ******<br>
Organization:  *****<br>
Site ID:  ###### <br>
Expires:  11/30/2016 <br>
Number of Users Allowed:  #### <br>
Microsoft Windows 7 Enterprise  64-bit (6.1.7601.65536)<br>
Service Pack 1</pre>
Re: Print JMP version and details in jsl
jmpversion()
"13.0.0"
"12.2.0"
"11.2.1"
"10.0.2"
" 9.0.1"
" 8.0.2"
" 7.0.2"
" 6.0.3"
the leading blank in JMP 6,7,8,9 is intentional.  JMP 5 does not have the function.
Also, from the scripting index:
and...
JMP Product Name();
"Pro" (or "Standard")
and...
Build Information();
"Feb  9 2015, 06:42:57, Release, JMP Pro"
Build Information is mostly for our internal use and the format has changed over time.  You should use the JMP Product Name() if it does what you need.
jmpversion()
"13.0.0"
"12.2.0"
"11.2.1"
"10.0.2"
" 9.0.1"
" 8.0.2"
" 7.0.2"
" 6.0.3"
and...
JMP Product Name();
and...
tsandidge
Wow...a couple more ENTERs with my keyboard, and there it was in the Scripting Guide. I'm ashamed.
Thank you for enlightening me!
