anasrullah
How do I connect to MS Access database in JMP 10?
I can't seem to connect to an MS Access database in JMP 10.  The script below works fine in JMP 9.  The error I get is, "[Microsoft][ODBC Driver Manager] The specified DSN contains an architecture mismatch between the Driver and Application".  Do I need to use a different driver ID?
Here is my script:
dt = Open Database(
"DSN=MS Access Database;DBQ=T:\Applications\Executables\Temescal Particle Count database.accde;DriverId=22;FIL=MS Access;MaxBufferSize=2048;PageTimeout=5;UID=admin;​",
"SELECT [Particle Data].[Tool Number],
[Particle Data].Date,
[Particle Data].[Tool Type],
[Particle Data].[Inner Row Pre Meas],
[Particle Data].[Inner Row Post Meas],
[Particle Data].[Outer Row Pre Meas],
[Particle Data].[Outer Row Post Meas],
[Particle Data].[Control Pre Meas],
[Particle Data].[Control Post Meas],
[Inner Row Post Meas]-[Inner Row Pre Meas]-[Control Post Meas]+[Control Pre Meas] AS RowA_Adders,
[Outer Row Post Meas]-[Outer Row Pre Meas]-[Control Post Meas]+[Control Pre Meas] AS RowB_Adders
FROM [Particle Data]
WHERE ((([Particle Data].[Tool Number])='Temescal 2800-10' Or
([Particle Data].[Tool Number])='Temescal 2800-13' Or
([Particle Data].[Tool Number])='Temescal 2800-14' Or
([Particle Data].[Tool Number])='Temescal 2800-17'))
ORDER BY [Particle Data].[Tool Number], [Particle Data].Date;"
Thanks!
Re: How do I connect to MS Access database in JMP 10?
My first guess would be that your MS Access is installed as a 32bit application, and you installed JMP as a 64bit application.  You can not mix bit levels.  You will need to uninstall JMP 10, and reinstall it as a 32 bit application.
anasrullah
Thanks Jim!
Jeff_Perkinson
Alternatively, you could install a 64-bit ODBC driver for MS Access.
-Jeff
