Hi all,
There have been several posts that have been helpful but I am still left wondering about a couple of things. To be clear, this is for the JMP Predictor Screening platform and not JMP Pro Bootstrap Forest.
The results of the predictor screening are the result of a bootstrap forest model. The question(s) I have are (and the first has been asked before): What is the contribution value? Is it G squared or SS depending upon data type? Also, the results are based on a bootstrap model, but we have no way of knowing if that model is reasonably good. Can we assume that if all the portions are roughly the same, the model that ran in the background is probably not great (or as was pointed out earlier, there is an important variable missing?
