LukasKuerten
Prediction profiler does not work if formula contains row statement
I can't get the prediction profiler to display predictions if my formula contains a Row() statement.
MWE:
the Formula for Column5:
:x
works fine:
while the formula for Column4:
:x[Row()]
results in the prediction not being computed:
Obviously I wouldn't need the Row() statement in the above MWE, but I've run into this problem while trying to build something somewhat more involved. I'm using JMP 16.12.0
Cheers,
Lukas
Re: Prediction profiler does not work if formula contains row statement
The Row() function used as a right-hand value will return a constant, invalid row number (0). It is meant to be used as a right-hand value in the argument to the For Each Row() function.
See help about iterating over rows.
What are you trying to do? In what way is a row number important to your purpose?
LukasKuerten
I'm using the Row() function in the formula for a formula column, not in a standalone script. Shouldn't Row() return a value for each cell in this case?
The formula column I'm trying to profile calculates the cumulative sum / numeric integral of column x up to that row. I've both tried the built-in Col Cumulative Sum function and explicitly programmed the iterative solution int_i = int_{i-1} + x_i , but neither work with the profiler.
Yes, the Row() function will return the current row in a column formula.
So your formula looks something like this one?
If(
	Row() == 1,
		:x,
	:x + Lag( :x )
LukasKuerten
Exactly, except it's Lag(:integral)   (i.e. the column itself), not Lag (:x)
