UserID16644
Level V
How to check if list value exist in folder?
Hi all,
I have files that needs to be checked if it is existing in a folder. If it does not exist, a prompt will show which file names are not in my list. Here's a snippet of my code:
//Sample Data
dt = Open( "$SAMPLE_DATA/Quality Control/Diameter.jmp" );
New Column ("Machine Op", Character,
    Formula
            ( "Machine_" || :MACHINE || " Op_" || :OPERATOR )
dt_list =associative array(column(dt, "Machine Op" ) <<get values) <<get keys;
//Files in folder
directory = "C:\Users\Desktop\Machine Operator Reference";
fileNames = Files In Directory( directory );
/* if dt_list does not exist in fileNames, prompt data table with missing file */
Re: How to check if list value exist in folder?
UserID16644
Level V
How can I transform this into an array?
The variable fileNames, is a JMP List, which is similar to an array.  Elements within the list, can be referenced by subscript;
fileNames[3] returns the 3rd file name from the list.
If you are asking, how do you move this into an Associative Array
dt_list=associative array(filenames)
