Hazal
Prediction Profiler Response Limit Constraints
Hello I have fitted separately response surfaces for 4 responses using 16 factors. I have one response to maximize (response 1) and three other responses that i want to use as constraints  which have upper limits. By using the profiler i want to maximize the response 1. But when response 1 is maximized, response 2,3 and 4 should not exceed a certain value. I adjusted the response limit for these responses and chose the goal as none. However these limits are exceeded when i choose maximize desirability. Is there a way that i can find the maximum value of response 1 in the defined range for response 2,3 and 4.
Thank you.
Victor_G
Re: Prediction Profiler Response Limit Constraints
Hi @Hazal,
Welcome in the Community !
If you specify the target as "None" for the other responses, JMP will only take these responses as an information, and it will not create any constraints on the optimization done by the Profiler.
Please check the response I have given on a very similar topic, you may find something that works for your case : https://community.jmp.com/t5/Discussions/Constrain-Response/m-p/605092/highlight/true#M80761
If you would like to have more précisions/advice, can you share an example dataset and more details about the constraint values for the responses ?
Victor GUILLER
Victor_G
Hi @Hazal,
Victor GUILLER
Hazal
Thank you, that is exactly what i needed.
