acid1c
Prediction Formula
These guides (A Chemical Mixture Example and Save Columns) state that I can access the Prediction Formula for a given column by using the menu:
Save Columns > Predicted Values
I am using JMP 12 and this menu is nowhere to be found. Where should I look?
louv
Staff (Retired)
Re: Prediction Formula
acid1c,
This can be found in all Fit Model platforms under Red Triangle> Save Columns>Prediction Formula.
louv
Staff (Retired)
acid1c,
acid1c
Thank you
