vs90
How to remove "where" condition from Contol Chart displays.
I'm plotting three different charts(IR,EWMA & CUSUM) in a single window but the problem I'm facing is it's displaying the where condition used within charts on the display window as well.
Display Window:
Code:
obj=New Window("Trend Analysis Report "||Long Date(Today()),
vlb=V list Box()
display=Function({Process,Label,By,Src_Type,lmt1,lmt2,lmt3},
r1=New Window("",
plb=Panel Box(" Control Charts for "||Process||" & "||" Source Type= "||Src_Type,Current Data Table(dt);
H List Box(
Control Chart(
Sample Label(Column(dt,Label)),
Group Size(1),KSigma(3),
As Column(dt,Process),Individual Measurement(LCL(lmt1[6]),AVG(lmt1[5]),UCL(lmt1[7]))),
Where(As Column(dt,By)==Src_Type);
Sample Size(1),
Alpha(0.00269979606326021),
Show Limits Legend(0),
As Column(dt,Process),CUSUM(Two Sided(1),AVG(lmt2[5]))),
Sample Size(1),
KSigma(3),Weight(0.2),
As Column(dt,Process),EWMA(AVG(lmt3[5]))),
);vlb<<Append(r1);r1<<Close Window;
plot=Function({lmts,pmt_path},
param_dt=Open(pmt_path,"invisible");
param_summ=param_dt<<Summary(Invisible,
Group(:Group By,:Process,:Sample Label,:By))<<Show Window(0);
For(q=12,q<=NRow(param_summ),q++,Current Data Table(param_summ);
col2=:Process[q];col3=:Sample Label[q];col4=:By[q];
Current Data Table(lmts);
clms=lmts<<Get Column Names(String);
Remove From(clms,1,3);
For(t=1,t<=N Items(clms),t++,Current Data Table(lmts);
indv_lmts=As Column(clms[t])[lmts<<Get Rows Where(:Parameter==col2 & :Chart Type=="Individual")];
cusum_lmts=As Column(clms[t])[lmts<<Get Rows Where(:Parameter==col2 & :Chart Type=="CUSUM")];
ewma_lmts=As Column(clms[t])[lmts<<Get Rows Where(:Parameter==col2 & :Chart Type=="EWMA")];
display(col2,col3,col4,clms[t],indv_lmts,cusum_lmts,ewma_lmts);
I'm not able to figure out why it is happening. Any help would be appreciated. Thanks!!
mpb
mpb
Re: How to remove "where" condition from Contol Chart displays.
See if this example is helpful. I modified an example in the excellent JSL intro Jump into JMP Scripting by Murphrey and Lucas.
dt = Open( "$SAMPLE_DATA/Quality Control/Diameter.jmp" );
cc = Control Chart(
    Group Size( 1 ),
    KSigma( 3 ),
    Chart Col( :DIAMETER, Individual Measurement ),
    Where( :MACHINE == "A386" )
Wait( 2 );
(Report( cc ) << Parent)[Text Box( 1 )] << delete;
Wait( 2 );
David_Burnham
The text for the where clause is standard output from JMP and not specific to your code.  For example for this script:
Control Chart(
    Group Size( 1 ),
    KSigma( 3 ),
    Where(:Machine=="A386")
The output looks like this:
Unfortunately this text doesn't seem to appear in the display tree and so can't easily be removed.  The approach I take is to create subsets of data for each chart so that the where clause is not required.  If I am composing a window containing multiple charts then having the title "Control Chart" doesn't add any useful information so I replace this text with the selection clause used to subset the data:
Here is the full script:
dt = Open("$SAMPLE_DATA/Quality Control/Diameter.jmp");
// column name used for 'where' clause
groupName = "Machine";
// need this to do housekeeping after the close window event
ns = New Namespace("temporary-tables-to-be-deleted");
// get unique values for machine
Summarize(levels = By( AsColumn(groupName) ) );
nw = New Window("My Charts",
      hlb = H List Box()
// iterate over each value
ns:lstTables = {};
For (i=1,i<=NItems(levels),i++,
    // create the data subset
    matchingRows = dt << Get Rows Where( AsColumn(groupName)==levels[i] );
    dtName = "Subset for " || groupName || "=" || levels[i];
    dtSubset = dt << Subset(Rows(matchingRows), Output Table(dtName), Invisible);
        // add to namespace for referencing by the on close event
        InsertInto(ns:lstTables,dtSubset);
       // use a container to ensure the chart is not rendered until appended to the window
    container = V List Box(
      cc = dtSubset << Control Chart(
            Group Size( 1 ),
            KSigma( 3 ),
    // revise the title
    rep = cc << Report;
    ob = rep[OutlineBox(1)];
    ob << Set Title(groupName || " = " || levels[i]);
    // append to the report window
    hlb << Append( container )
// housekeeping - delete the subset tables
nw << On Close(
    ns = Namespace("temporary-tables-to-be-deleted");
        For (i=1,i<=NItems(ns:lstTables),i++,
            Try( Close(ns:lstTables[i],NoSave) )
And the associated output:
-Dave
-Dave
vs90
Thanks for the input David. That seems to be a good approach and will definitely try it out.
Although was looking for quick solution in the meantime and mpb's solution worked out well.
But your approach also is quite self-explanatory for end-user to interpret the charts well.
mpb
mpb
cc = Control Chart(
    Group Size( 1 ),
    KSigma( 3 ),
Wait( 2 );
Wait( 2 );
vs90
Thanks mpb. That's what I was looking for an exact solution.
