nac
nac
Population bioequivalence approach of FDA
Dear all,
FDA has a guidance for in vitro bioequivalence of products between test and reference. The name of this statistical test is Population bioequivalence.  Please find test details below link; https://www.accessdata.fda.gov/drugsatfda_docs/psg/Budesonide_Inhalation_Sus_20929_RC_09-12.pdf
Is there anyone help for calculation of this test by using jmp?
BR,
Re: Population bioequivalence approach of FDA
JMP added hypothesis tests for equivalence over many versions. The Population Bio-equivalence test is not currently implemented, though. Some might study the paper that describes this test and the calculations, and then write a script for JMP, but it would have to be validated.
In the meantime, you might go to the Wish List area. Search for a suggestion to add this test and if you find one, vote for it (kudos). If you do not find one, then add your own!
