dilipkumar
Populating the data in new table with variable defined in script
Hi all,
Actually i am trying to perform a calculation in jmp script, i have defined these calculation using a variable. ( ie- a,b etc), now i trying to populate this variable into a new table, such that each time if input changes , calculation will change and new data will be populated in new table.
let us assume a= weibull function( consider every input i have for calculating a)
dt = New Table( "Result",
	New Column( "X",
		Expression,
		"Nominal",
		Set Values( {a} )
in new table i am getting output as a, not the value of a. i want value of a to be populated.
Thanks,
Dilip
Ryan_Gilmore
Re: Populating the data in new table with variable defined in script
I think you may need to add some rows the table.
dt = New Table( "Result" );
// Method for inserting a function
b = Expr(
	Random Uniform( 1, 10 )
dt << New Column( "Y", continuous, "nominal", formula( Name Expr( b ) ) );
dt << add row( 5 );
In the first example, setting the values of column X automatically generated the rows.
Ryan_Gilmore
Hi @dilipkumar ,
Not knowing what the variables (a, b, etc.) might contain, here are two examples if the variables contain a list or a function, that will populate the column with the values defined by the variable and not the variable itself,
// Method for inserting a list or a matrix
a = [1, 2, 3, 4];
dt << New Column( "X", Continuous, "Nominal", Set Values( a ) );
b = Expr(
Hope that helps.
dilipkumar
My variable is function, it return some values,
i tried using your second example, i am getting empty data table named " Result"
Ryan_Gilmore
b = Expr(
dt << add row( 5 );
