Nickbuon1
Pooled within-groups correlation matrix
i am trying to locate where in JMP is the 'Pooled within-groups correlation matrix.'
I have looked at Multivariate and Discriminant  analysis. I can see the correlations and the correlation probability output. But i am looking for the 'pooled' within group correlation.
Anywhere i can go in JMP?
Nick
Re: Pooled within-groups correlation matrix
I do not recognize this term.
Nickbuon1
here you go. I have attached some screen shots and my JMP data.
most of the JMP data does not really match up well. Some do or come close.
I am afraid that the example of the results still does not explain to me what the pooled correlation matrix represents or how it is estimated. I am not an expert in MANOVA, so perhaps another community member with such expertise can help.
Unfortunately, I'm with Mark.  I don't understand what you want or why you want it.
Actually, you had the result that you wanted. Use Analyze > Multivariate > Discriminant. Enter the 5 covariates as Y and the visit as X. The linear discriminant function will provide a table if you click the red triangle at the top and select Show Within Covariances. You get the table that was shown in your Word document.
