frankderuyck
Plot eigenfunctions FDE
Can someone explain me how to plot the eigenfuctions in the FDE. Attached is a the NIR modeling %Octane Gasoline dataset: how to plot the 4 eigenfuctions versus NIR wavelength? Thanks
Re: Plot eigenfunctions FDE
The minimum BIC selects the model with no FPCs. You can drag the vertical handle in plot found in the Model Selection outline to the right to select more FPCs. For example, I dragged it to select 6 FPCs:
